Fixed parameter by Type for nested family
mgilliver
mgilliver
Hi All
I'm sure that this has been answered before OR I'm just going the wrong way with the idea.
The question is in two parts,
1. I have a range of say 3 items for which I have created a family for each of them. I've then created a new floor based generic family and loaded each of these families in. Using family parameter/label, I can then select each of the 3 items from the family types window. All good so far...but. I then create 3 types. I want Type 1 to ONLY be allowed to show Family1, Type 2 - Family 2 etc. I see that as I change the Type name, I can choose a different Family from the label I created while in the family editor. Great. BUT, when I then load this into a model, if I choose 'edit family' I can override this parameter to any of the other families. I tried using the formula, but that seems to lock the family for ALL types. Should I be able to link/lock the family selection to the Type?
The only other answer I can see is to have completely separate families for each of these 'similar' items. Note that the items are not parametric in terms of dimensions, they only come in 3 different fixed 'models'.
2. Additional Parameters for the above. Very similar to the above, I want a parameter/value associated which each type that cannot be changed. I've created an integer TYPE parameter. Lets same Type 1-Family1 has Integer 2. Ie this model has 2 whatevers. Type 2-Family2 has Integer 4, ie this model has 4 whatevers etc. Again, I can set the Value field and click through the types in the family creation, but when I load to a project, anyone can edit this. They could theoretically set Type2-Family2 to an integer of 16. Oh, and I need to be able to report/schedule on the integer.
I know I'm missing something basic....please point me in the right direction.
PavelAnd
Hi @mgilliver. If I understand correctly ... Below is an example of the implementation of this task, and in the attachment there are that families (R2019).
I recommend adding a visibility parameter to the nested family so that the geometry is exactly hidden.
Best regards, Pavel Plotitsyn.
mgilliver
Hi Pavel
Thanks for this. It does solve it, however I was trying to do it without using visibility parameters as I might have another family to create with up to 10 variations, so managing the settings and items in view will get very complicated. I was taking the approach of labels/family types after reading another post recommending that for anything more  than 2 options, you should avoid using the visibility option.
The if(AND) part of your solution solves both parts of my question, but not in a way that works with labels/nested families.
mgilliver
I realised the problem was more at the root of the family in that I was nesting multiple components that really should have been parameter driven to avoid a massive family size. after a lot of reading my family went from 15MB (I know!) to 1.2MB and didn't need visibility parameters.
A type catalogue was the easiest solution or I may change to lookup tables at some point.
mgilliver
Ok - I still need help after finding my own post after all this time.
I have an item with 3 types. It is only available in 3 different geometries. I create each type and amend the dimensions for each. When I load it into a project and look at the type properties, I am able to manually amend them. So i can create an item that simply doesn't exist. How do I prevent that?
