Filter on comments
Filter on comments
Oliver_Malmkvist
Filter on comments
Oliver_Malmkvist
I have created a filter which filters out all objects that has a value in the built in comments parameter. But when I do this all object which at some point has had a comment but later has been deleted also filters out.
Any idé why this happens?
jay_colcombe
I think if you use "Has a Value" even when deleted it thinks at some point it is no longer Blank even though it contains no value
You are better using "Greater Than" and leave the value blank
Jay Colcombe
Autodesk Certified Instructor
Oliver_Malmkvist
Thanks, that worked!
