Extrusion color not shown up in Plan view
Hi, I'm creating a model for which I have set the material as concrete. If I draw the structural floor its showing up from the PLAN view(in grey color), But in case I'm creating an Extrusion (same) it is not shown from plan view, only the lines are showing up(no color like in structural floor).
But, when I see in 3D it looks perfectly fine, shows the grey color.
ennujozlagam
set you detail level  and visual style to different setting and see if you can achieve the correct colors and see if helps. thanks.
I changed the bottom range to unlimeted and it worked.
