Extension Line of View Title
walidinJKACC
Message 1 of 9
walidinJKACC
I always export revit sheets to .dwg file.
But why after exporting them to dwg file, Extension Line of View Title can't be printed because of having different layer.
Because of this problem I must do "matchprop" every view title in dwg, everytime after getting revision, and it takes very time consuming.
How to make the Extension Line of View Title in revit AUTOMATICALLY able to be printed, and i dont need to matchprop everytime ???
you can see this screenshot:
Image-1 (On revit sheet)
Image-2 (after exported to dwg file)
Image-3 (after exported to dwg file)
Replies (8)
Message 2 of 9
virgilio_benedictos
Hi @walidinJKACC ,
check your export setup and remove the -NPLT letters from your setting for "View Titles" see image below. the sample of automatic non-plottable layer  removed the NPLT.png
Message 3 of 9
walidinJKACC
I follow your instruction to remove -NPLT, but now the problem is that viewport line also appears when printed to real paper or pdf.
See this pdf screenshot after exported to dwg from revit as test to real paper.
Message 4 of 9
virgilio_benedictos
@walidinJKACC ,
Do not Change for the settings for Viewports. that's only a sample of a setting that has NPLT,  in your case, it might be your View title has NPLT in your settings,
Message 5 of 9
walidinJKACC
@virgilio_benedictos
how the behavior of the viewport and viewtitle should be separated
Message 6 of 9
virgilio_benedictos
@walidinJKACC ,
in the edit Family environment, you can set the other elements in the sub-category for you to able to control the visibility.
Message 7 of 9
walidinJKACC
I didn't change anything about viewports
Message 8 of 9
walidinJKACC
1. extention line doesnt appear as default in family environtment, but in sheet view it always appears. how this can occur?
2. How to differentiate layer for viewport and extension line  by setting in revit
Message 9 of 9
robertbTNH4Q
@walidinJKACC Did you ever find a solution to this? I'm having the same problem.
