exporting DWG transparency\hatch problems
Sahar-RONM
Sahar-RONM
Here is a print screen of a projected smaller wall and elongated cut wall above it with floor in between and the model setting:
when exporting this to a DWG file it shows the element like this:
I tried to change several settings but nothing works including the export DWG setup with no change visible.
I'm desperate. does anyone have an idea?
jay_colcombe
It appears the Background only is being exported in the Hatch - so check the Hatch Properties in ACAD
I recall an issue with Revit 2024 and Structural Template where transparency was applied, and this caused an issue so make sure you have ALL updates installed.
Missing pattern while exporting layout including Revit links to DWG from Revit
For earlier version there was also an issue with the following setting "Export Rooms, spaces and areas as polylines" so that hatches are not being exported.
If you uncheck this checkbox the export should work properly again.
Hatches are missing when exported to DWG from Revit 2021 and Revit 2022
Jay Colcombe
Autodesk Certified Instructor
Sahar-RONM
Hello Jay and thank you for your answer.
I did all of the above including updating but it didn't solve the problem
