Export IFC From Revit Structure
gopijMAW6D
Observer Observer
gopijMAW6D
Observer
Observer
Hello Every One,
I exported IFC from Revit Structure and i imported in Tekla and I open the Organizer check the parametric(Before IFC  Conversion in Tekla). I didn't get the Part weight in organizer. Any Setting is there in Revit structure Before Export IFC any one know please Suggest me.
Thanks and Regards,
Gopi.J
Jason.P
Once you select Export IFC, do not hit export yet. Go and change your "in-session setup" and "modify setup" as required to make sure you are exporting all the required parameters and analytical information needed.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
gopijMAW6D
Observer
Observer
Hai Jason,
Thanks for your Reply. I Tried but i didn't Get the Part weight in Tekla Organizer(Before converting Member in Tekla).
Can you explain how to get the Part weight in Tekla Organizer. any setup in in Revit Please screen share.
