Export analytical link from revit to Scia Engineer
markogiannaki.olga
Observer Observer
markogiannaki.olga
Observer
Observer
When I create an analytical link between a structural column and a beam,having already checked the box analytical link to the properties of the column, it does not seem to be transferred  from Revit to Scia Engineer. However the manual shows that it should have been transferred. What else should I do? Maybe I make something wrong? Anyone who knows about the connection between those two programs may give me a piece of advice. Thank you  in advance.
gevanKGYB4
I do not use SCIA programs so I am just offering my experience using other programs. What I found is that the transferring of the analytical model is highly dependent on the 'cleanliness' of the analytical model in Revit itself. The 'linking program' does have some factors in the transfer also although this is very user specific in this case since everyone may use different engineering programs. In cases like this, it would be best to talk to the SCIA support or community forum rather than here since it would be more effective. I am sorry if this does not fully help (or at all).
