Exploded Lines AutoCAD export
anaszok12
anaszok12
Hi everyone,
Currently I'm trying to create layouts in Revit, and matched everything to our firm CAD standard.
However, I encountered a small problem where the lines are exploded (negligible) and what I saw in Revit is not the same what i exported.
For example,the yellow rectangle represents a column, all good in Revit but when exported to AutoCAD, certain parts are replaced by green lines, which is a beam. Eventually, I had to edit in AutoCAD and wasted my time. Please refer to the pictures below for reference
Thank you in advance
There is an option under export settings to retain overlapping lines. And what is the purpose of exporting to DWG?
anaszok12
We exported to AutoCAD for printing
