Explode or Split Rebar Set
Hi all
I am modeling the reinforcement for the precast panels using structure rebar in Revit 2019
somewhere I have to shorten a piece of rebar(inside set on rebar) at the connection location.
Is there any way to explode a set of rebars so you can modify its parameters (without adds on just Revit 2019)autodesk.JPG parameters?
_Vijay
if you upload a sample Revit I can try.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Mohamed-Nassar
you can make this set manually
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
