Error running Analysis in Cloud after Changing Members with User Defined Section
I tried changing all members in the Revit model to User-Defined Sections and then run the analysis in Cloud.But it has the following errors. Can anyone tell me what is wrong here? Thank you. (Model and section families files included.)
George
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Additionally you have to  set Material for Model Behavior in families definitions.
Fixed Revit model attached.
Rafal Gaweda
Thank you Rafal for the answer. I can run the analysis after selecting that!
However, may I know will the selection (say concrete) affect the material properties that have been input manually which is not concrete nor steel?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
No, it does not.
Rafal Gaweda
Good. Thanks Rafal
