Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
English Canada family error dimensions with Revit french version
1 REPLY 1
francois.st-hilaire
219 Views, 1 Reply
I have mesurement error using English Canada family with Revit french version. If a insert a structural column CISC HSS Square(CSA G40.21)-Column  152x152x4.8 into a drawing, the mesurements are 254x254mm. I have mesurement erros for all members. If a start Revit with the parameter /language ENU the mesurement are ok.
Does exist a solution if i want to continu using the french version ?
Thanks !
1 REPLY 1
Hi @francois.st-hilaire
Importing an English Canadian family into a project using French Revit
 is not supported. When the English family is opened in French Revit, the parameters get automatically translated into French (they are standard parameters coming from Revit sw), but the txt type catalog associated with the family stays in English (because it's a static text file).
Revit tries to fill in values for the French family parameters from the text file, can't find any (because the names don't match... that's what the error message is about), and the family gets loaded incorrectly.
This in turn leads to those weird issues with different dimensions in English and in French after import (the dimensions basically get corrupted).
French templates will always throw the errors, because they do not contain any of the CISC families (they need to be imported, which fails), while the Canadian templates do contain some CISC families already, so the problem wouldn't be visible there right away - not until you try importing additional types from the English txt.
Have you checked out this article yet? Country specific structural steel sections families cannot be used running any languages for Revit
Forma Design Contest
