Editing the connection of beams
stevensonJQWEF
stevensonJQWEF
Hiya,
I have made a post and beam structure for my building in revit.  When I drew the beams, they all connected to the midpoint of each post (showing the triangle symbol).  But now that I need measurements I would like them to connect to the edge surface of the joining post.. so that I know the real measurements the beams should be.
Is there a way I can change this for the entire building without manually reconecting each and every beam?
Thanks in advance!
Ahmed_Muharram
you can use length or cut length from the proprieties of the beams one is measuring the drawing line and other the clear span
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
