Edit type pile foundation but rebar don't auto change.
Message 1 of 8
 Hi guys, I've a issue with rebar in  pile foundation.
When i place rebar in pile foundation (my family), after that, i change my type foundation
But rebar don't auto change.
Note: Rebar was hosted to foundation.
Thank all !
Replies (7)
Message 2 of 8
Hi
I am new here and I am a tourist guider at  Kapasan Dargah]Chittoor Dargah , Chittorgarh Dargah  and Chittor Dargah.
Best regards
Hazrat Deewana
Message 3 of 8
ovidiu_paunescu
Hello @Anonymous
Currently for round columns (or piles) rebar can only be constrained to the top / bottom faces.
To add the main reinforcement you can use a polar array.
More info here:
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/e9bb11d1-ccf0-470e-9727-ca94816a4591.html
If the section changes, you need to manually edit the reinforcement.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 4 of 8
-FDC-
Hi there,
You asked me to help you with this issue in a private message but I'm afraid I don't understand your question.
Message 5 of 8
 Sorry, You can see issue at this.
223311
Message 6 of 8
ovidiu_paunescu
Can you upload a sample file with this behavior?
Message 7 of 8
Yeah, this's my file.
Message 8 of 8
ovidiu_paunescu
What happens here is that when changing the foundation type to D400, the faces of the foundation get different IDs.
The rebar fails to react correctly due to this change of ID (as this is the way the bars know which face to follow) and manual editing is required.
I've noticed that using a pile foundation family in the Revit library doesn't show this behavior (e.g. M_Pile Cap-4 Pile.rfa)
Maybe a workaround would be to start with this family and customize to get the desired shape.
