Edit Analytical column
atelier.absinthe
atelier.absinthe
hello guys, I just have one question ....
Once I created the family of Column from template "Structural Column Metric" how do I change the analytical part of the column with a square section?
If I wanted to create an "Y analytical model"? ... or if you just want to decentralize the analytical model in a columnwith a square section?
I tried searching on the web but could not find anything. 😞
thanx! 😉
Facchetti Davide - www.studiofacchetti.com
Davide Facchetti | Architect | Studio FACCHETTI | Bergamo - IT
Rafal.Gaweda
Autodesk Support
Autodesk Support
No way
After placing it in model you can use the options shown below
Rafal Gaweda
atelier.absinthe
ok thanx!
I think there was a "graphic" method!
Thank you
D.
