DWG Preview without having a initial view
hanslammerts
hanslammerts
Using more then one Revit release i noticed that sheets exported to DWG are allways come out without visible data in modelspace view.
While a preview is made correctly there is no initial view stored. See att. A checkbox in the export options to store the initial view would be welcome.
How do you export to DWG?
FAZIOGREG
I use the regular dialogue to export.  There is an option in that to export all views on a sheet as xref's.  I like that cause it reminds me of my cad-monkey days...
Is there linework on one of the other tabs?  It looks like you are in the Layout 1 tab in your image.
hanslammerts
The constructionworld is a zoo full of monkeys and bimgeeks.
I think you and i use the same method to shake de banana from the tree..
hanslammerts
save it with tilemode 1 will do it adsk
