Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Dwg export- does not display white filled region
3 REPLIES 3
olga_protsenko
362 Views, 3 Replies
When exporting some drawings from Revit to dwg, the white filled region stays black in dwg. With the same settings for the drawing and the export, the export works fine on one drawing and not on others. I also use the same family of the filled region.
3 REPLIES 3
anze.kumar
in reply to: olga_protsenko
Did you actually use the same colour in the Filled Region. Because you can see that in autocad the colours are actually not the same. Revit treats "white" colour different as Colour (255-0-0).
olga_protsenko
in reply to: anze.kumar
Hi, yes I use the same white. Actually I just copied this 2 elements from one sheet to another.
anze.kumar
Hey, what is the colour that is assigned in Edit Type option?
Forma Design Contest
