during opening some views - fatal error
montrevg
montrevg
Good day,
Suddenly fatal error during to open some views (sections).
View templates same but some of views and sections make fatal error during opening.
I tried to find what is the problem, step by step hide -Turn off the visibility for all elements.
It seems the problem in Framing elements.
What is the way to fix this ?
Thank you.
See attached.
L.Maas
Some things you can try:
-Audit your project file and see if it comes up with anything
-Check your journal file after crash happens, see what causes the error (HERE about location of journal files)
-Check for updates (Revit, OS, Graphics Drivers).
-Delete the problematic view(s) and then recreate them.
-See if it is a specific family that causes issues. Simplify it or Remodel it.
Make sure you have backups.
Louis
Please mention Revit version, especially when uploading Revit files.
montrevg
Thank you.
I assumed that the problem (corrupted Revit 2019) occurred during the installation of Revit 2021. The audit did not give any notification.
My colleagues open the same model in Revit 2019 - no problem.
In my case, reinstalling Revit 2019 on the computer-this is not necessary, because I alone made this model (neither central nor local, etc.)
Now I continue to work in 2021.
Thank you.
lim.wendy
Hi @montrevg,
Thank you for posting. It looks like @L.Maas  provided you with steps to recover your model/project, so for now I am going to mark this as "Assumed Answered." This won't prevent other folks from commenting on this question though in the event other ideas come up!
Remember, marking your posts as having an accepted solution really helps out other forum users that have the same issue – so don’t be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems.
If the solution did not work, you can unmark the post as an accepted solution. To cancel an accepted solution, click the ellipsis menu  > Not the Solution.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
