Double Angles Steel Connection Error
m_rashadRDLAZ
Observer Observer
m_rashadRDLAZ
Observer
Observer
Did Autodesk solve the problem of Double Angles Steel Connection Error in Revit?
or anyone has an idea to generate a connection for diagonals Steel Double Angles??!
jay_colcombe
I do not think this has been implemented from the Help on the subject.
Help | Supported Structural Steel Shapes and Families for Steel Fabrication | Autodesk
A quick check and Computer says no!
I created a Gusset Plate for one diagonal and then mirrored the Angle Brace and offset the Y value the thickness of the Plate and it didn't break which may be open to modification?
Jay Colcombe
Autodesk Certified Instructor
m_rashadRDLAZ
Observer
Observer
Thanks, Jay, for your response
but i believe this is the known current approach for going around this issue but it consumes a lot of time, and for that i was asking if there is another solution .
