Disallow join between Structural columns and Structural Foundation
aasutosh_gupta
aasutosh_gupta
 I want to Disallow join between Structural columns and Structural Foundation (Isolated Footing/Pile). Whenever I change the column base offset the foundation should not move with column base. How do I fix it in whole model.
JeandreVDM
Select all your foundations and change their level to a lower one in the Properties panel. This will automatically unjoin them.
See attached video. Hope this helps.
aasutosh_gupta
Hi JeandreVDM,
 Thank you for your solution and I understood that this is the only one tricky solution currently which can help me easily.
