different cut pattern for the same structural columns in the same view
hemmanu
hemmanu
hello,
i have created a structural column.
i found that a different cut pattern appear for two columns
i have compared all parameters and checked all view filters and did not fine a clue.
if i copy the column with the "line pattern" the appearance stay the same
if i  create similar it gives me the smooth pattern column....
thanks for any help. Hagay.
the two same-different columnsthe two same-different columns
sureshchotrani
Kindly let us know the version of Revit you are using.
Is it 2016, 2017, 2018 or 2019?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
sampie
Hi @hemmanu
Could you upload the sample?
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
hemmanu
i'm using Revit 2018
thanks, Hagay
hemmanu
Revit 2018
hemmanu
Do you mean to upload the Revit file itself?
sampie
Hi @hemmanu
Yes please.
Kind Regards,
Sampie
