Detailed Calculation report for Connection Design Code Checking
aw383
aw383
Hello
Is it possible to get the full detailed calculation report for a connection design when using the code checking tool? The output report attached does not show how all the terms are calculated - it would be nice to be able to get a full output report showing all the calculations.
mihai.sandu
The option to control the report explanations/details is located in the Settings\Display Options menu.
Setting the display in as much detail as possible, still doesn't produce a report that shows how each parameter is calculated. Geometric values, resistances, stiffness's and some other parameters are calculated by Revit in the background and populated in the report.
Mihai Sandu
Sr. QA Analyst
