Delete Legends not placed on sheets
NFTech86
NFTech86
Does anyone know of a way to delete unused legends from their model? I've tried purging but this doesn't appear to include legends.
Thanks.
Edit: Im looking for a way to know what legends are unused/not on sheets so I can delete them without having to manually go through each sheet.
hmunsell
You can just select them in the Project Browser, Right click and Delete them.
Howard Munsell
hmunsell
you can also try using eTransmit
  • in the Upgrade and Cleanup section...
    • select Include all sheets and
    • only include views on sheets
Howard Munsell
NFTech86
Yes, but im looking to delete only the ones that are unused. There doesnt appear to be a way to see what legends arent on a sheet so I dont delete one that is needed. Changing the browser organisation to show views "not on sheet" doesnt cover legends, so im at a loss on how to identify these easily without manually going through every sheet.
hmunsell
i assume you're not using 2023 or newer? in 2023 Revit added a box in front of the view that displays if it is being used on a sheet.
  • Blue is used on a sheet
  • White is not used on a sheet.
Howard Munsell
NFTech86
Unfortunately not. Its great to know a solution is there for future models.
hmunsell
We're in the same boat.... most of our projects are still in 2020 due to client requirements. but we a handful in the newer versions too.
Howard Munsell
