Cutting rebars with a reference plane
I have modeled a bridge in Revit using the SOFISTIK Bridge modeler plugin for Revit.
I want to model the prestressed cables in the bridge. The workflow is as follows :
- Define secondary axis describing the geometry of the prestressed cables
- Create Revit rebars from said axis geometries, having the concrete superstructure as host element.
Here is a screenshot of my progress :
The problem is, the bars are created along the whole defined axis, and there is no option to define a length for secondary axis.
My question is : is there a way to cut the rebar using a reference plane for example? Or any trimming for rebars option in Revit / Dynamo that would work in my case.
Your help is much appreciated, I have attached the file I'm using.
kent.w
I don't believe there is a way to cut or trim the rebar in this model.  I'll have a look to see if there is another way to manage it with Sofistik
Kent Watson | AIPAL
www.aipal.com.au
