customize project browser
nadifa.aulia
nadifa.aulia
Could anyone give me an idea how to make the left one turns into the right one? Thank you! Have a great day 😁
jay_colcombe
It appears the Schedule on the Right has an Additional Shared Parameter added to the View to allow it to be categorized to another reference as per this example - so you need to add in a Shared Parameter into the Template
And then Grouped/sorted by This Parameter
Jay Colcombe
Autodesk Certified Instructor
nadifa.aulia
nadifa.aulia
So I must have that "shared parameter" to customize the project browser? Could you elaborate more? thankyou! 😄
nadifa.aulia
is it what you mean by add in shared parameter? https://www.youtube.com/watch?v=MLAGbgxmsEM
jay_colcombe
Yes that is exactly it!!!
Use this guidance to create the exact same scenario - just name it inline with what you want/need.
The View Usage can then has as many References as you want you just Type in a new one and they get added to the drop down list when used.
In your example these would be the 01. and 02. etc. references
Jay Colcombe
nadifa.aulia
i found the the solution on this website. Thankyou https://mashyo.com/setup-the-project-browser-in-revit/
