Custom Spot Coordinate Target
i am trying to change the look of the spot coordinate indicator. i have managed to change the arrowhead and the filled region of the target, but cannot get the surrounding circle and lines to change. i would also like to be able to extend the length of the text line. attached is a snap shot of what i am trying to achieve. I am sure this is possible but can't find the location of the spot co-ord family to make the change.
Alaaeldin_Alsahli
For the circle, I suggest you to create a new spot elevation instead of the existing one.
And for the Extendable line, Use length parameter for dimensionning the line and need to create types.
Here is a video that shows all these steps
https://screencast.autodesk.com/main/details/a0500613-6a7c-4f86-9e60-133e1a57004d
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
ekennethschafer
Wanted to take the post a step further. Can you into a Revit system family: spot coordinates and add a label that is editable so you can pull in the coordinates as well as give it a title for example Pile 001, next line N 2', w 5'. where Pile 001 is an editable label?
droman7HU5G
has anybody found a solution for this?
