Trying to create a custom shape that in plan has a straight section and then a slight bend, but also has the option of having a standard 90 degree hook on the end in the Z direction. Is this possible?
I've been able to use the Sketch Rebar and get it to show up properly by doing a Multi-Planer shape, however I manually have to adjust the "hook" length (uses the C parameter), anytime I modify it the C value resets and it also doesn't show it using the Standard Hook.
Plan - Sketched in place
