Custom beam dimensions.
jessicaBWP2S
jessicaBWP2S
I would like to create a custom dimension for beams, where I have the length and beam tag including the dimension lines to the edge of the beams.
Until now I 'hard coded' it to look according to our needs, but I would like it to be integrated and change as the elements change in Revit.
This is the current dim, is there a way to combine a tag with the dimensions?
Kind Regards
Jessica
WALIDGIO
edit tag family and add to it system length or cut length according to you need, or do a math equation to it.
