Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Curved roof analytical model
4 REPLIES 4
592 Views, 4 Replies
All
I am trying to recreate a curved roof made of steel beams. We have an IFC of the model. Is there a way to snap to endpoints on analytical beams? I have tried SE but for some reason that snap doesn't work.
4 REPLIES 4
sampie
Hi @Anonymous
Does "Pick Lines" with 3D Snapping enabled not work?
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
in reply to: sampie
Yes I had 3d snapping on. The odd thing is sometimes it snapped and sometime it doesn't. All very frustrating.
Rafal.Gaweda
Hi @Anonymous
In general snapping does not work for analytical objects.
It may happen You think it is snapping to analytical end when analytical model line is located on top flange (default for beams) but in fact it snaps to end of insertion line.
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks for the reply. It would seem a failure with the program then. I can't see how I can use the analytical model to transfer to the Engineers design software. I hope this is this something that may be improved in the future.
Forma Design Contest
