Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Curved Concrete Beam
8 REPLIES 8
Message 1 of 9
180271B3SK2
495 Views, 8 Replies
Hey,
I need some help with creating a curved beam in Revit 2022. I've got a model with a roof (attached), and I want to add a curved beam underneath it. Check out the picture I've included to see the side view where the beam needs to go.
I've tried a few times to do this myself, but I keep hitting a wall. If you could try it out and then provide some guidance or solutions, that would be really helpful.
Thanks in advance!
8 REPLIES 8
Message 2 of 9
180271B3SK2
in reply to: 180271B3SK2
IS there someone available who could provide me with assistance?
Message 3 of 9
jay_colcombe
There are 2 options:
  1. When you create the beam use the Pick Line option in the drawing panel, this will allow you to use the existing shape for the beam path.
  2. Create a Model In-Place Family with a Structural Framing Category.  You will then create a Sweep with the Path being determined by the Roof Edge Line and the Profile can be a Structural Framing Profile or sketch it manually.
Take a look at this similar solution;
https://forums.autodesk.com/t5/revit-structure-forum/profile-beam-allong-ramp/td-p/12274093
Jay Colcombe
Autodesk Certified Instructor
Message 4 of 9
180271B3SK2
in reply to: jay_colcombe
Option 1 Didn't helped me, when i pick line using 3d snapping, it say error that curve is sharp.
Is option 2 helpful enough to create analytical model of that beam and cut length of beam?
Message 5 of 9
jasoncolcombe
I think you are limited in output due to the complexity of the Structure your are trying to associate it with
Message 6 of 9
180271B3SK2
in reply to: jasoncolcombe
EXACTLY
Message 7 of 9
180271B3SK2
Actually, I Dont need just Geometery. Later, I will use model for Structural analysis, Sheet Generation and Quantification too.
Message 8 of 9
jay_colcombe
You can do this with a Sweep, just tried it here and it worked okay.
Jay Colcombe
Message 9 of 9
180271B3SK2
Yes dear,
I tried sweep too but it looks OK from from front but on backside the edge of beam is exposed, not merged in slab.
Again there is problem of analytical model
