Creating structural wall with Dynamo nodes
Noriyasu.Haruta
Noriyasu.Haruta
Hi, all.
I'm using Wall.ByCurveAndHeight node to create walls. Using this node, I can make an architectural walls. Does any of you have answer to create structural walls with Dynamo?
Dynamo windowDynamo window
View in structural disciplineView in structural discipline
View in architectural disciplineView in architectural discipline
palo974
Your script seem to create a structural wall.
The Structrural view don't show physical wall but only analytical wall
Go to VV to set visibility of your wall.
But it seems that the hight of your analytical wall is not set. You should see a panel not a bar.
Patrice
Noriyasu.Haruta
Thank you for sending message.
In my opinion, the wall I made is not structural discipline wall does not have analytical model. According to the image below, it's not ticked structural box.
Revit3.PNGIf I use Dynamo to create structural walls, the only thing I tick it after creating architectural walls. I would like to know how to automatize this process.
NH
EdwinG
@Noriyasu.Haruta
By default the architectural wall is drawn so you have to set the parameters Structural and Structural Usage.
Noriyasu.Haruta
Hi EdwinG,
Thank you for your solution. I will repeat trial and error about parameters more.
NH
EdwinG
i learned also with trial and error
see this site for a lot of help and info https://forum.dynamobim.com/
see this for learning https://primer.dynamobim.org/01_Introduction/1-1_what_is_visual_programming.html
iboschFRHFP
Observer
Observer
hope you are well.
is it possible to use dynamo and have my retaining wall protrude 1000mm into & along topography and add a strip foundation simultaneously?
