Creating a Face Based Void Family where Face itself is at an angle
geteway2digitalindia
I need to create a [face based - circular in plan - void creating family] where the face is at an angle...[face & void orientation are not mutually perpendicular] however the void will run parallel to the screen axes.....therefore the depth of void will vary along the slope.....
It can be treated as a special case of the face based void creating family where the face & void orientation are mutually perpendicular.
Please suggest
jay_colc
Could you not simply Create a Model In-Place Void Sweep Blend with different profiles at each end to create the varying void depth?
Jay Colcombe
Autodesk Certified Instructor
I want to park aside Model-In-Place as the last resort....
I am researching on dedicated parametric family as my first priority.......
jay_colc
I think you possibly need to be a little more detailed on what you are trying to achieve as an end result as its not very clear?
Jay Colcombe
rosie_lucas1
Hi @geteway2digitalindia,
I wanted to check in and see if you saw @jay_colc follow up request for more detail.  Is assistance still needed or have you found a solution to your question already? Please share any available information so the community can assist you further.
Rosie | Community Manager
