CREATE PRECAST WALL PANEL AND ITS SCHEDULE
nadifa.aulia
nadifa.aulia
Hello everyone! I have some kind of fundamental problems here, for introduction let me explain my goals.
So I have this plan layout, it defines the types of precast wall panels that I used (PC-G2. PC-G1, etc)
as you can see the wall is divided based on the type. The problem is, how can I create these types of precast walls and also the schedule that contains their section properties? I already tried it with walls and columns, for walls its sections appear but it doesn't work for L-shaped. For the column, its section properties (width, height, depth) can't appear and my walls have a void too, i think modeling it as a column may not work well in the future.
Thank you, have a good day! 😀
Don't you have precast tool within Revit?
nadifa.aulia
i have, but i have my own configuration to split wall, it cant be developed using default precast Revit tool
You can create parts from walls and divide parts.
