course overide
course overide
frank_dewan
course overide
frank_dewan
Community Visitor
Community Visitor
Can you override some beam member in revit structure to become fine that are in a course view setting. opng.jpg
debimmanager
Hi @frank_dewan
You should try with phases.
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
jbrazier
Select the members you want to change, in the Properties change Structural Usage to Other.  Go to Object Styles, under Structural FramingOther and change the value for Projection to the Line Weight you're looking for.  Changing the phase creates other issues.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
You need to create a dedicated family for those and edit the family to show Fine geometry for Coarse, delete or make Coarse geometry invisible.
A_MAQ
this is a view specific option , it's apply to all elements in view, the only solution is to go to family itself and edit the visibility setting , you may create a yes/No instance parameter to control the visibility of geometry , as you know structural framing having two geometry one for fine setting and other for medium and line for coarse
Autodesk Expert Elite
