copy/paste problems
copy/paste problems
Message 1 of 8
copy/paste problems
I was pasting from a linked (architectural) model into my structural model.  All was going well until my paste button quit working.  I can copy but the paste option is grayed out, as if there's nothing on the clipboard. It still works with some elements but not others.  I was attempting to copy walls and doors, and had literally finished copying about half of the floor of a house model when I encountered the problem.  I had already copied the entire floor below and all the windows and exterior doors this way.
Any differences between the elements I copied previously and the ones I'm trying to copy now are unknown to me.  I've never had an issue with this previously.  I am using Revit 15 on Windows 7.
Replies (7)
Message 2 of 8
sureshchotrani
Can you share images what elements while you select are not getting pasted?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 3 of 8
L.Maas
This can happen sometimes depending on the elements and how they are positioned in the model. If items are linked to other elements or workplanes or orphaned these issues sometimes crop up. If you cannot see the issue immediately you will have to find the problem by trial and error. Copy small parts of the items you want to copy and slowly zoom in on the problematic items.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 8
Here is a screen shot.  I believe it was the doors on the left half of the floor plan that were the problem.  I was trying to select the walls and doors, which I did on the lower level with no problem.
Message 5 of 8
I got around it by doing a copy/monitor, but I prefer to copy the elements themselves so I want to understand what happened. Doing further investigation, I think it was 2 doors that were causing the problem. However I copied doors, windows and walls together on the lower level. I'm not sure why these 2 particular doors caused a problem.
Message 6 of 8
chrisplyler
I just guessing here. Perhaps Revit won't let you paste doors or windows that you've copied without also having their host wall selected during the copy. I mean they cannot exist without a host wall.
Message 7 of 8
You are correct. They will not copy on their own, or at least not paste properly. I was selecting the host wall simultaneously with the doors, so although I was able to narrow it down to the doors that were the problem, I'm still not sure why they were. Other doors copied and pasted with their host walls no problem.
Message 8 of 8
I am finding that no element from this particular model can be copied and pasted into other files. Even if i create new ones with no hosting. Any ideas?
