Attention for Customers without MFA or SSO - OTP Verification rolls out April 2025. Read all about it here.
Convert of RFA file to STEP
dragonsuperbat
dragonsuperbat
Hi, I am looking for some help to convert the attached .rfa to a .step file as I do not have an access to revit. Your kind help is much appreciated,
mphungDCHNW
you can export it as a DWG in Autocad then save it as a STEP
dragonsuperbat
@mphungDCHNW
Is it possible to open a rfa file in autocad at the first place? I have tried, but can’t
mphungDCHNW
You can export a RFA as a DWG from Revit and open it in Autocad but then you would be going around in circles
Here is DWG, you can import it in Solidworks and save as STEP file.
