Convert all existing vertical straight rebars to L-shaped bars
shuaib009
shuaib009
How can i change all existing vertical straight rebars to L-shaped bars  at ends (for whole project) without much effort. (I think there are at least thousand bars)
@Sahay_R  @ennujozlagam @RDAOU @ArmanMargaryan @ToanDN @barthbradley
@jay_colcombe
jay_colcombe
If you have the Host Name you could try and Filter in a Schedule per Host and then Shape and Select in the Schedule (Hold Shift+Click Row)  and change the Shape.  You could even Filter by Length etc. to really focus in on specific items.
Alternatively you could Select > Right Click > Select Similar but this would be a little open to interpretation on where it selects objects
Jay Colcombe
Autodesk Certified Instructor
shuaib009
Hi @jay_colcombe ,
Thanks for your response. I tried doing it, but may be I am not doing it right.
I have attached Revit file. I want to change all vertical and horizontal bars from straight to L-shaped at both end about 150mm in least possible effort.
Windows key + Shift + S will allow you to record your screen, Please explain it in video if time permits you. 🙏
