Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Convert ACIS to Polymesh objects
2 REPLIES 2
kentanner1346
18494 Views, 2 Replies
Importing autocad piping into project and recieve the following error : 'ACIS objects could not be imported, use qutocad to convert to polymesh objects'   any help would be appreciated !
2 REPLIES 2
If you are using an AutoCAD MEP DWG file, have you tried going through the steps in the following blog posting:
Importing 3D geometry from AutoCAD MEP into Revit MEP
http://revitclinic.typepad.com/my_weblog/2011/04/importing-3d-geometry-from-autocad-mep-into-revit-m...
I also found the following help topic with information on the type of ACIS objects that Revit supports for import:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0061-Start_a_61/0066-Using_In66/007...
Lance Coffey
Technical Support Specialist
Files where exported into dwg format from CATIA. Don't and can't find alot out about this application, however found if I would explode and purge the files I could then turn them into blocks... worked fine for what i needed.. recorded a little macro and 57 files in about 2hrs...
Rail Community
