How do you get REVIT to control laps and cut reinforcement to stock length e.g. 12m?
hi
it is not in every tool, in the RFT extension when you use it for beams you will see division of main top and bottom bars.
not all Rebar tools have this option, so you will have to do it manually or use an extention from autodesk exchange store
https://apps.autodesk.com/RVT/en/Home/Index?from=infocenter
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
sir,
In the reinforcement extension you have mentioned below, there is no provision of adding multi main bars for example if i want to add 25mm@2Nos and 20mm@2Nos then how it is possible?
Unfortunately not possible in Revit (let's hope for the next release).
You can try this as a workaround (starting from page 46):
