continuous beam DIFFRENT SPAN SECTION
dalhoumi400
dalhoumi400
HI
I want if possible how to Create a continous beam with DIFFRENT SPAN SECTION my problem is when a creat each beam with a diifrent family i can t import the rebar from DIFFRENT SPAN SECTION becuse the numbre of span
what i want is to creat a continous beam with a section for each span
A1.1(22x30) A1.2(22x50).....
thnx
dalhoumi400
i found this
https://forums.autodesk.com/t5/revit-structure-forum/continuous-beam/m-p/4428487
i have the same probleme i cant find the solution
Ahmed_Muharram
if it's a multiple span Beam it's not applicable as for my knowledge you will have to draw it as single span beams
you will have to draw and edit the rebar for each span.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
DALHOUMI400
thanx;
if i do that how can i make the rebar ?
DavidDillonJr
@DALHOUMI400 @dalhoumi400
 I learned the most about rebar from Autodesk Design Academy. I suggest you use your Autodesk ID and log in. After you login search for Cert Prep for Autodesk Certified Professional: Revit for Structural Design.
Lesson 2 Video 16 Working With Reinforcement tools Part 4 will help you the most, use create reinforcement path.
David Dillon
