connecting structure
hi any idea how to make construction in revit with the model in my sketchup...
i am not sure how it connects and form the facadeand the roof
hmunsell
to clarify... Are you trying to bring "Revit into Sketchup" or "Sketchup into Revit"?
Howard Munsell
sketchup into revit. i try to mdoeling in revit but cannot complete the structure and the facade and the roof... hope u can help . thank u
hmunsell
you can import a SketchUp file into a family or a project. BUT you will not be able to interact with it like Revit content. if I remember correctly... the Sketchup file will come in as a Mass element.
Import SketchUp Files
Limitations of SketchUp data imported into Revit
instead of using Sketchup to patch your Revit model, what i would recommend is open another post and explain the issue your having with Revit and your Facade/Roof. See if anyone can help with that.
Howard Munsell
