Greetings,
I may be called upon to draw a room in Revit. The room appears to be made from concrete tip up walls with a concrete ceiling. The walls should be okay (once I find and add the wall to my library), but how do I make the ceiling?
I'm uncertain how to draw in the waffle shaped concrete that makes up the ceiling. Would I render those as concrete walls that intersect using the bottom as the base and the floor above as the top of the wall?
Thank you. I think this should work for me. I will be modeling this off of a point cloud. It seems like either way might work?
No, I haven't tried slab edge. I'm basically very inexperienced when it comes to Revit. I took a basic class last summer, but haven't had any work with it. I will definitely see if I can find some YouTube videos on this too.
Thank you.
Try a slab with intersecting concrete beams. That may be the simplest solution.
