complete floor assembly
Why does Revit still not allow for a proper floor assembly with joist & rim board - the beam system never meets the rim board nor is there a place to add it.
Thirteen years using this product and it still has not been added as a function.
Please advise how to make complete floor assemblies.
Thank you
Brian
Revit_Whisperer
I think maybe I am not understanding completely...it is true that there is no rim joist included in the beam system.
You can add beams (rim joist), create your beam system, then once it is done select the joists and change the start and end cutback to 0.Floor framing.jpg
mariah.ferranti
Hello @Anonymous,
Thank you for participating in the forums! I wanted to check to see if Revit_Whisperer's workflow answered your question.
Please feel free to select 'Accept Solution' on their answer if the information was helpful, or reply back if you have more questions regarding beam systems that meet rim boards.
