07:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone!
(Sorry for my english...)
We were working in a collaborative model, and we find with this problem:
The columns (a lot, no just the one of the example), are attached to certains levels with a Base Offset and Top Offset of 0.00, but they are over the top level and below the base level (As you can see in the image). If you change the Base Offset or Top Offset to another value, the colums reflect changes correctly, however if you get back to the original 0.00, the error comeback too. The same occurs if you change the Base/Top Level and back to the original.
Someone knows what's happen?
Thanks!
***The columns are not attached to floors
***I upload the model
