Column Line Weights when plotting
ddengHGF47
Message 1 of 8
ddengHGF47
I want to change all my column on the foundation plan to line weight 1.
After having changed projection/cut line weights for the columns in Object styles, they are still printing out very bold (like in line weight 5 or heavier). Am i missing something? Or is there an alternative method?
Replies (7)
Message 2 of 8
ennujozlagam
try here at VG and see if helps. thanks
Message 3 of 8
ddengHGF47
Nope, it is still the same after I overrode both the projection/cut line on VG.
Message 4 of 8
Karol_Piroska
the above should probably be structural columns, not columns. Make sure to check filters as well
Message 5 of 8
ddengHGF47
The (structural) columns are still coming out heavy after changing the line weight in Object Style and VG. There are no filters apply in this project, should I be using one?
Message 6 of 8
Jason.P
Have you checked your Visual Style for that view. It may be set to the wrong one.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Message 7 of 8
ddengHGF47
I figured it out. Under structural columns in object style, "stick symbols" was controlling the boldness of the plot.
Message 8 of 8
jim6MZ9S
Thank you so much for posting the solution. I was checking everywhere and nothing was working. This worked perfectly
