Column hosting rebar failure
02:13 AM
HI everyone!
So my problem is the following. I have an instance of a column that is intersected by a concrete beam at the level above and there is a piece of concrete wall liyng on top of that beam. The thing is that when I try to add a rebar to the column it won't allow me to do so. I would probably say that this has something to do with the cover of the column as it doesn't show up either. I've attached the video below so you can see there is an identical column next to it and it can host rebar actually.
If you know whay may have caused this problem please share the solution. Thaks in advance.
