I tried to make custom structural column family. Some parameter can not change.( such as column length, corbel location, corbel size etc.) I wonder why they can't change even I made exactly same with built in revit column family.
Solved by lim.wendy. Go to Solution.
Solved by recep.eliacik. Go to Solution.
In the family, since you didn't assign a parameter for the lenght, it can be changed by levels, you can assign base and top level and offset distance for lenght.
I hope it'd be helpful.
First thank you for your reply. I already tried this method. But After uploading to project, I can't change anything. Length is fix. Location is fix.
It's wonderful. Don't mind can you show me some screenshot if you have time cause I'm just beginner.
Here is a screencast for you.
Hi @tpcsoelin400,
Thank you for posting. It looks like @recep.eliacik provided you with the steps to change the parameters of your column, so for now I am going to mark this as "Assumed Answered." This won't prevent other folks from commenting on this question though in the event other ideas come up!
Remember, marking your posts as having an accepted solution really helps out other forum users that have the same issue – so don’t be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their issues.
That solution what I'm searching for over month. Now I got solution morn than column. Thank you so much @recep.eliacik. 😀.
