Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Cloud files are not opening completely
2 REPLIES 2
lucas_andradeRT86B
157 Views, 2 Replies
 All of my cloud files are not opening completely, even after I clear my cache files. The only solution I've found is to reinstall Revit, but I'm tired of doing that repeatedly.
 Whenever this problem occurs, I become unable to open the model until I reinstall Revit.
 Does anyone know how to fix this?
Labels (3)
2 REPLIES 2
JL.FCG
in reply to: lucas_andradeRT86B
Are other team members having this problem, or is just your machine?
Is Revit up-to-date?
Antivirus blocking application from creating temp files?
Corrupted Windows profile?
Slow network?
Tried to open file without Worksets and links enabled?
Iv found most times that iv seen this issue, its usually to do with 3rd party applications/add in's.
lucas_andradeRT86B
in reply to: JL.FCG
 It worked with the next steps:
 - Clean the cache files on the local and roaming files;
 - Clean the temp file
 - Stop the add in's
 Thanks for the reply!
 Regrats, Lucas Andrade.
Forma Design Contest
