When working with fabrics, the external face of the wall seems to be the standard face for adding new fabric. Is there any way to change this?
The reason this is an issue is that when working with sandwich walls, there may be a surface change on the external side (e.g. 20 mm thinning), which causes there to be no fabrics anywhere in the wall within that area, i.e. no fabrics in the structural wall (or anywhere else for that matter) because there is no wall on the face that the fabrics are being added to.
So far I've tried defining a different face by setting the work plane as something other than the front face of the wall, but to no avail.
Best solution I have is to split wall into parts and then add the fabric to the structural part itself. But that still leaves the cover part without fabrics where it's been thinned.
Just in case, by thinned I mean 20 mm have been aken fro mthe cover, but retaining the concrete thickness.
