Changing slanted column to vertical column
chriskD6WP2
chriskD6WP2
Is there a way to change a slanted column to a vertical column?
jbrazier
Yes there is.  If you manually "straighten" the column to vertical, using the grips, you can change the Column Style (in the instance properties) to Vertical.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
