Change the project base point elevation
I see many questions similar to this, but can't find exact the same thing.
I am moving the building elevation +40cm, so I moved the project base point elevation 40cm down to achieve it.
All the drawings were updated accordingly, and it's all working out, except that when we upload to the Dalux (something like BIM360 in germany), our model still shows as original elevation. This Dalux shows all the models together to see any clashes.
If you see the screenshots, you will see before I moved the base point and after. I see the coordination arrow (x,y,z) is still in the same spot. I am wondering if this is the reason?
Any suggestions would be appreciated!
Thank you!
